Gen 3 3.2 Did Preventative Maintenance
Posted: Fri May 06, 2011 10:03 pm
Hi all,
I need some wisdom with my Did currently on 220 000km. I searched this forum and Ozzy ones for componenents with a higher incidence of failure (or then more serious consequences in the event of a failure).
I recently (December 2010, while on holiday) had my clutch and dual mass flywheel replaced at 22K at the dealers. Didn't give me much warning and failed. Further cost me a couple days of my holiday, 200k's on a flat bed and a few gray hair. I would like to prevent something similar as far as possible, but should still make sense financially.
Two months later my starter had to be replaced (fortunately gave me warning this time). I had a reconditioned unit fitted by the dealers for +- R5k.
My paj has a "oil sweat ?" on the tappet cover gasket which is due for replacement at the next service (now). I thought of having the tappets checked and adjusted if nescessary and the timing chain top guide replaced. How far do I go - do I replace the chain and tensioners or only if any problems show up on inspection ? What about the other 2 timing chain guides ? (according to dealer 12 hours labour to get to, according to Malcolm in Maitland about 6 hours
Then on the cooling side - what do I do ? I read about replacing thermostat, radiator cap, heater pipe T pieces. Is it nescessary to replace rubber hoses preventatively or only on inspection ? Which ones is most important ? Do I replace a water pump preventatively ?
I recently replaced all aircon and alternator belts, but see some people recommend replacing pulleys as well. Do I replace pulleys / bearings or only if noisy ?
The much discussed oil pressure switch ?
Heat sender unit ?
Is there anything else that I should have a serious look at at this mileage ?
Current plan is to do the tappet cover gasket, top guide etc. first.
Any advice ?
Thanks,
Wessel
Heat sender unit ?
Any advice ?
Thanks,
Wessel
