This relates to the Touareg, but could be of value to other vehicles with electronic Traction Control.
I need to have the centre support bearing on the Touareg's propshaft replaced, but I need the vehicle to drive around with.
I was wondering whether I could remove the propshaft and use the Touareg in Front Wheel Drive mode?
What would happen in
- normal (open centre diff) situation
- CDL on (low range)
EDL
Electronic Differential Lock (EDL)
The Touareg has four-wheel EDL. Using four-wheel EDL, a freespinning
wheel is slowed by brake application, transferring torque to a
wheel with traction.
- will the ECU interpret the situation as both rear wheels lacking traction (both "freespinning") or
- will it not realise this because neither of the rear wheels are in fact "freespinning"?
If at the wheels, I suspect that it will try to transfer power to the disconnected propshaft, and I will lose all drive?
