2.5 Tdi Turbo reconditioned & 3.5 V6 throttle body cleaned
Remember to clearly mark vacuum pipes in order
Normally 5x bolts holding the housing in place (4x in front & 1x on side bracket)
What the throttle body should look like, after thorough clean-out (including rear inlet housing) & no play on butterfly shaft
Achille
:D
Blister
Re: 2.5 Tdi Turbo reconditioned & 3.5 V6 throttle body clean
Achille ad I did both our Blisters onthe same day and I found it extremely "comforting" and fun.
I filled the tank (petrol + 2T oil) and after journey to Citrusdal and back recorded 11% improvement which equated to 6km/l. Still good but improvement :roll:
I am still confused why the ECU unit had to be opened because it was very clean inside :?
