BFG: Tyre Pressures
Posted: Mon Jul 25, 2011 8:57 am
by Duppie
Hi Guys,
Just fitted my first set of BFG's.
What is the correct pressures to run BFG's 265/65/17 in the following conditions:
- Daily commute - 2bar?
- Sand - 1bar?
- Rocks - 1.5bar?
I got them at 2.5bar currently it seems to me too high. Also road noise is much higher than expected.
Dup
3.2 LWB 2006
Re: BFG: Tyre Pressures
Posted: Mon Jul 25, 2011 9:13 am
I have 16" on my pajero and run them 200kpa at all times - my driveway is 4km of dirt road.
If I plan to drive long distance I bump the pressures up to 230kpa.
If I plan to go offroad I drop them to 130-150kpa.
Posted: Mon Jul 25, 2011 9:15 am
by SimonB
4ePikanini wrote:I have 16" on my pajero and run them 200psi at all times - my driveway is 4km of dirt road.
If I plan to drive long distance I bump the pressures up to 230psi.
Idf I plan to go offroad I drop them to 130-150psi.
Marius
How about metric :) We live in a metric country ... and if you can pump up tyres to go offroad to 9 bar, be my guest
Posted: Mon Jul 25, 2011 9:20 am
by SimonB
While pressure vary according to vehicle and wheel sizes, I used to run my BFG's at 1.8bar for general commuting, 2.2 for highway when loaded, 1.3 for offroad and 0.8 for sand
Posted: Mon Jul 25, 2011 9:35 am
Marius
Fixed !
Dad to the rescue!
(He spends to much time on the USA forum!)
Posted: Mon Jul 25, 2011 9:38 am
If you are serious about finding the correct pressures, the "4 PSI" rule is the closests you will get to the correct answer.
(Google / search "4PSI rule")
Posted: Mon Jul 25, 2011 9:55 am
ok ok ok. My mistake. :oops: I usually just look at the numbers, not the denominations. hehe :?
