97' V6 3000 Valve Stem Seals
Posted: Fri Aug 12, 2011 12:14 pm
Hi Guys,
I have read with interest the rope method used by bold4E and 4EPikanini in the "3.2 DI-D Valve Stem Seal" post. I am about to do my valve stem seals on my 97' V6 3000 using the explained rope technique. This is quite original
I would like to ask a few more questions please:
1) When I feed the rope into the combustion chamber, do I fill the whole area all the way to the top?
2) Will it then let the cylinder travel all the way to the top - or do you reach the required effect on the valve with the piston halfway up the chamber and not being able to go up further?
3) If this happens - the tensioner will then have to be slacked in order to turn the engine counter clock to release the tension and retrieve the rope?
Any further tips - Marius - Waldo?
Appreciate the help
Jaco
Appreciate the help
Jaco
