Reverse lights and air temperature gauge
Posted: Tue Sep 20, 2011 6:41 pm
Hi Guys,
Could somebody please help me, I have a 1997 2.8 SWB Pajero with 2 problems.
The reverse lights don’t work, I have checked the switch on the gearbox and the fuses under the dash and all is well, also power getting to the switch on the gearbox and to the fuse under the dash.
The other problem is the temperature gauge on top of the dash does not display the inside or outside temperature.
I have found the inside temp. Sender unit under the steering column and it appears ok. I also removed the 3 gauges from the dash and saw only wires feeding the temperature gauge, there were no globes visible so I don’t know how they display, the other two gauges had a globe with a blue cover.
VincentT
VincentT
