Oubaas
Snorkel. yes or no?
I am considering fitting a snorkel. Is it worth it?
Cleaner air, better breathing?
Before spending the money, i would like to hear from you guys who had one fitted.
Re: Snorkel. yes or no?
Cleaner air?
Possibly, if you drive a lot of gravel roads. The intake is higher off the ground.
Better breathing?
Yes/No, depending on your current setup.
The snorkel loses out on the length of the intake tract, which means some losses.
(Forget about the 'ram effect', unless you travel at 150km/h plus).
The main advantages are:
  1. Looks :)
  2. Protection against water ingress during water crossings
Oubaas
Thanks Fuelly Gerhard. So you reckon it is a good thing, if I do a lot of off roading? Water through your intake can do a lot of damage?
Oubaas wrote:Thanks Fuelly Gerhard. So you reckon it is a good thing, if I do a lot of off roading? Water through your intake can do a lot of damage?
It won't do any harm, and could save the engine from a hydro-lock, which as you said, is often fatal (for the engine).
Oubaas
Thanks Gerhard...I am ordering one now. You need one at a stupid low price? :D
Oubaas wrote:Thanks Gerhard...I am ordering one now. You need one at a stupid low price? :D
For a Gen1?
Price?
Oubaas
+ - R 750. Gaan jou in elk geval onder R 1000 kos.
Oubaas wrote:+ - R 750. Gaan jou in elk geval onder R 1000 kos.
Vir 'n Gen1?
Vervaardiger?
Photos?
Oubaas
See photo below.
Gen 1.JPG (13.86 KiB) Viewed 2017 times
AboutAfrica
For that price I would buy 2. Best price I found for my Gen 2 was R1800.00
Paid 6500.00 for the tritons snorkel :cry:
And with 4e, I would def recomend a snorkel.
