Freshman
Best spots
Hi all,
Sure some of you must have installed lights into the front bumber of the Gen2.5 (Blister) underneigh the head lights.
The "holes" sit at a bit of an angle so I was wondering if there is a spesific type or make that works well there?
Or did most go for very small round spots mounted at the back?
paw_by_paw
Re: Best spots
Freshman,
I still wanted to install Hyundai Tuscon fog lights . I have the lights but have yet to examine the probable method to install.
I will attempt once my vehicle is back and running.
Freshman
Re: Best spots
i'll watch this space then... :)
Another thing is the backlights which has nothing in the top compartment (was thinking extra brake lights would be nice) and also nothing in one of the smaller lens areas - maybe additional indicators there??
Any ideas?
buurman
Re: Best spots
I am also considering the same mods, will keep eye on this post. How about LED's in tail lights?
tonton
Re: Best spots
I am also interested.
I thought something like these examples could work, if fitted to the steelwork behind the plastic overriders:
As far as LED's are concerned, Achille (Nino62) and Aslam (Blister) tested their hands on this - maybe they can give feedback?
paw_by_paw
Re: Best spots
Freshman.
When I got my vehicle the top lights were connected as an extra indicator light but icidently I stripped the whole wiring system out to standard as have experienced som problems with fuses not lasting. It might have been bad wiring but the standard is what is for now.
I have also removed the front bumbers and saw that fitting these fog lights will not be an easy task as mentioned by you the angles is a bit crooked but I am going to give it a go anyways. The problem is make brackets that will actually work and before I cut those holes want make sure I do the right thing.
Freshman
Re: Best spots
buurman wrote:I am also considering the same mods, will keep eye on this post. How about LED's in tail lights?
Check this post:
https://www.pajeroclub.co.za/forum/view ... =27&t=3084
