Net 'n Boertjie
Running in a new Pajero 3.8 - Your views please
Hi all
What is the modern requirement for "running in" a new vehicle, specifically the MIVEC 3.8 motor. Is it at all necessary other than driving the vehicle normally for the first while?
Marius
Re: Running in a new Pajero 3.8 - Your views please
:D :) ;)
Enjoy it,
Roelf
If I one day buy a car I would keep it below 80% of redline for 2000km. Change the oil (I feel this is crucial to remove the bedding in metal bits for the new engine) and then go as I please.
Not manufacturer criteria, just my personal feeling.
Net 'n Boertjie
4ePikanini wrote:........... Change the oil (I feel this is crucial to remove the bedding in metal bits for the new engine) ...............
Thanks, does make sense. Suppose i could change the oil filter at the same time; or is that overkill? Should i get a "genuine" part to "hide" the bit of private maintenance; warranty issues?
IMHO definitely change the filter and definitely use genuine (they are cheaper than pirate anyway)
NB : I phoned for rear brake pads for my pajero today
Autozone - R690
Midas - R 980
Dealers - R600 :shock:
Net 'n Boertjie wrote: Suppose i could change the oil filter at the same time; or is that overkill? Should i get a "genuine" part to "hide" the bit of private maintenance; warranty issues?
If you don't want to change both oil and filter, you could rather change the filter and leave the oil!
I had an article (and lost it), where they drove a Opel 4-cyl engine for close on 200 000 kms, and only changed the filter every 10000 kms (IIRC). The oil was only topped up as required. No oil changes as such.
At the end of the 'experiment', they found that the engine showed no more wear than one that had the oil changed at regular intervals.
I would not recommend it, let alone do it, but it proves something!
Net 'n Boertjie
Hi guys
I replaced the oil and filter on the Pajero today. The dealer (Mitsubishi Boksburg) supplied me with a different oil filter though, part no. MD136466. It is slightly shorter than part no. MD352626, anyone out there gone through this exercise.
Had to use this "MD136466" as the original unit is now full of holes, i do not have a strapping tool at home.
Marius
paw_by_paw
Boertjie,
I have also heard not to tow anything heavy in the first 2000 km but it might be hearsy otherwise consult your manual.
I am aslo a strong believer in driving decently for the first 2000km just to make sure ring seating takes place normally :?:
dawiey
Net 'n Boertjie wrote:Hi guys
Marius
It seems that Mitsubishi is also not sure as to what oil filter must be used. I have replaced mine in September 2011 and they gave me the MD136466 one. Last week when another oil change was due the same dealer (Union Motors Nelspruit) supplied me with a MD 352626 and said that it was the only filter to be used. It is very confusing. Dawie Nelspruit
