Hello All,
I have a Gen 3 and I have a problem with the tyre pressure sensor, I already changed them 2 times and I sitll have some problems, the indicator light of the low pressure on the panel starts to flash, sometimes it stops and works well and sometimes it just starts flashing, I already checked the presssure accoring to the manual but still have the problem, does any one knows how to disable those sensors? the sensor that goes inside the rim should be connected somwhere, does any one know where is that cable located?? I will really appreciate if someone can give me a hand on it.
Thank you!!!
