Engine cutting out
Posted: Mon Dec 12, 2011 1:05 pm
by Dzombo
Hi, my Pajero has just started to cut out whilst driving. I took it to an auto electrician and he says it is not the electrics. Before i take it to a dealer i would like to know if anyone has expeienced similar problems before and what was causing it. What i have done is adjutsed the revs so the vehicle does not cut out but i have been told to take it in as it might be sucking in air.
Re: Engine cutting out
Posted: Mon Nov 12, 2012 2:42 pm
by phatmyles
Dzombo wrote:Hi, my Pajero has just started to cut out whilst driving. I took it to an auto electrician and he says it is not the electrics. Before i take it to a dealer i would like to know if anyone has expeienced similar problems before and what was causing it. What i have done is adjutsed the revs so the vehicle does not cut out but i have been told to take it in as it might be sucking in air.
Hi.
Did you manage to solve the problem? What was it? Mine started doing that last week, though it happens sometimes, and usually the problem goes away when I select a lower gear to get the revs up to 4000rpm for a few minutes. Mine is a 3.5V6 GDI.
What was your problem?
