Connecting Spotlight for dummies - Need Help
Posted: Fri Dec 16, 2011 7:45 am
by Davidvan
Hi there,
I am not very good when it comes to the electrical stuff, and don't want to cause too many issues :-). I have got a new set of spots I would like to connect to my normal high beam and need some assistance on how to do this. I preferably don't want to use the seperate switch provided.
Any assistance here would be greatly appreciated, wiring diagrams for Gen3, etc, have got the spots mounted and looks cool, now just the important part to make them work...
I found this one, but looks pretty complex for my limited electrical skills, thought it may just be earth connection and find the high beam power and I am done, or am I over simplifying it:
https://www.4x4community.co.za/forum/sh ... php?t=8006
David
Re: Connecting Spotlight for dummies - Need Help
Posted: Fri Dec 16, 2011 9:43 pm
by jotto
Howsit
Almost that easy, just need the relay in there. You arer welcome to come to my hose and I will do it for you quick, just bring the relay with- a proper one, like Hella, not the R30 cheapy please. :shock:
PM me for the details.
Cheers,
Johann
Posted: Sat Dec 17, 2011 3:53 pm
by Davidvan
Thanks a mil Jotto, they are a set of hellas and the relay is included so should be all good, will send you a PM.
Posted: Sun Dec 18, 2011 7:20 pm
by Davidvan
Thanks a mil Jotto, the spots look and work LEKKER now!
Posted: Mon Dec 19, 2011 8:38 pm
by cloyd
David,
Just a short "warning". I am of opinion that all spots/driving lamps must by law have it's own on/off switch. Installing such a switch is as easy as drinking a cold one!
Maybe one of the legal experts can comment on the legal issue.
Regards, Cloyd
Posted: Mon Dec 19, 2011 8:53 pm
by Davidvan
Thanks Cloyd, will definitely check it out.
Posted: Mon Dec 19, 2011 9:40 pm
by HBannink
Legal issues I can not comment on but it is a handy to have. Installing it is as easy as taking a set of wires to a switch inside the vehicle and cutting in to the line that comes from the main beam to switch the relay. In effect you cut the power to the relay from the main beam, simple and easy.
In the link above they have used a pretty similar setup but have switched the negative instead, being a sparky by trade I prefer to switch the live, old habits die hard :twisted:
Posted: Tue Dec 20, 2011 5:57 am
by Davidvan
Thanks Henk, will be adding a switch on the positive, that it very easy, thanks for your input. Rather be on the safe side here.
David
Posted: Tue Dec 20, 2011 9:20 pm
by cloyd
David,
Sorry this is a bit late, but the easiest way to fit a switch to de-activate your spots/driving lamps is to put a switch in the earth line from the relay. If this line is cut, the relay is basically dead and being the earth line, no power flows thru it.
Cloyd
