Cable from front to rear for Battery box
I've decided to go the battery box route, rather than the 2nd battery in the engine bay. (there are various reasons - e.g. space not such a big issue currently, and would like to use fridge / lights / etc when not close to the vehicle)
My question relates to the wiring I need done to the car, and some of the battery box wiring.
Based on all the reading I've done, I've come to the following conclusion:
  • cable thickness for LWB between batteries should be 16mm
  • will use 50amp in-line fuse close to the main battery
  • will be using the 50amp brad harrison connectors at the rear
  • will make a 'lead' of about 2m to connect the battery box to the connector at the back - will be using 16mm cable for that as well.
  • QUESTION: I want to install a second fuse close to the battery box. Should I do this close to the car connector in the cable running from the main battery? Or should I install it in the 'lead' I'm making? Or should I install it in the short piece of wire that runs from the battery box connector to the battery in the box?
  • will add fuses to the positive cables of all the connectors I'm adding to the battery box. QUESTION: Any recommendation on the amp rating of these fuses? (connectors are hellas, 12V and brad harrison for the fridge)
any help would be greatly appreciated
Karl
Re: Cable from front to rear for Battery box
Save yourself a lot of hassle and use a DC-DC charger.
  • No solenoids
  • Thin cables / wires
  • Intelligent charging (proper charging for a deep cycle battery)
I would... but COST! DC to DC is for later.
I will be removing the battery box when not camping/on vacation, so I can trickle charge otherwise at home.
I'm going to measure the voltage at the battery to check if its above 14.1 (or ideally above 14.3). This should mean that hopefully with the voltage drop I would be able to charge the aux battery to almost 100%.
Karl
well, good news and bad news...
startup is at around 14.3 - 14.4V... but after 30 minutes drive it drops down to 13.9V.
I did however switch on both aircons on full blast, and still it remained at 13.9V (before and after aircons), so I believe this is just the rate at which the regulator keeps it?
Any chance of adjusting the way the regulator works?
Karl
Your start up voltages are fine and the drop shows that everything is working the way it is supposed to.
The high voltage at start is because you have drained from the battery by starting the vehicle and the alternator is pumping out more to replace that loss. the aircons draw less power than the alternator can generate and when the start power has been replaced the voltage drops and will do even more so if the aircons are switched off
Henk Bannink
but I wont be able to fully charge the deep cycle with 13.9V :cry:
Karl
paw_by_paw
Hi Karl,
I found this on the net somewhere hope it helps for you.
I am also going the box way - later.
BatteryMate Isolater.pdf
(131.2 KiB) Downloaded 235 times
duel battery.jpg (9.75 KiB) Viewed 3138 times
another duel battery installation diagram.jpg (7.31 KiB) Viewed 3138 times
alternative wiring duel battery.jpg (10.25 KiB) Viewed 3138 times
oh wow, thank!
Funny how some guys swear by negative to the chassis, while others disagree totally.
personally, I wont do the negative to chassis. Just seems to increase risk of a short somewhere, with no fuse to stop it.
Karl
4ePajero wrote:Save yourself a lot of hassle and use a DC-DC charger.
  • No solenoids
I agree with oom 4E. After having had a solenoid National Luna now for many years and recently adding a DC-DC charger to my setup I can confirm that it really is what they all say it is. I have even been running my fridge in the back all the time even when just driving to work and back and the DC-DC charger pushes sufficient punch to keep it all topped up and still keeping some cooldrinks cold in the back. My solenoid system could never manage to do this and was drained after a few days when used like this.
Ok, ok... But maybe I don't fully understand the capabilities...
Where do you put the charger? In the rear with the batteries?
No need for solenoid then? Cable to rear is permanently connected to charger?
Cable thickness no longer an issue? Surely if you have more voltage drop the charger will take longer to charge?
Sent from a Desire HD with Forum Runner
