themba
Looking for pajero gen 2 spares Big ends ,main bearings
after recently buying a gen 2 3.5 swb i recently had the heads done,cambelt and tensioner,front and rear discs and pads water pump,oil change ,valve reset and just when i thought i was almost finished fixing it up now i recently drove the car over the week end for approx 300km and its developed aknocking sound on start up and a ggrrr sound when accelerating which leads me to suspect the big ends have gone .Can anyone kindly help with a contact where in can get big ends and main bearings at affordable prices .this car is fast starting to remind me of my experiences with a grand cherokee i once owned .please help thanks
Re: Looking for pajero gen 2 spares Big ends ,main bearings
themba,
We would like to help you, but you will have to give a lot more info.
  • Where are you based?
  • Who did the previous work? A qualified mechanic?
  • Don' you think the previous work could have 'caused' this failure? The co-incidence is a bit large.
  • Was the engine running well before the work done to it?
  • Just fitting new bearing shells will not necessarily fix the problem. What caused the failure? Broken oil pump? Worn bearings? Wrong oil? Blocked passageways? etc, etc, etc.
To me failed bearings (if that is what you are hearing) means total strip, investigate, machine, replace.
themba
Many thanks Gerhard .I am based in the North rand and the previous work was done by a qualified mech .Before the initial work was done the car drove but when i bought the car i knew i would have to do some work on it but didnt expect to find a blown head gasket when it was stripped and like i say when i got the car back after all this initial work was done it drove hundreds for those 200 odd km this past saturday when i took it to the vaal .Sunday morning while trying to move cars around then the knocking noise .I will take your advice and send it back where it was done i am assuming maybe replacing of big end s main bearings and oil pump after the investigation that is.thanks
