P.S.remember my motherlanguage is german, therefore my english
Hi there, my problem today is that i don`t get enough pressure out of the windshield window jets.I cleaned the jets, there is air flowing through the pipes,the pump is working.I removed the bottle, there was lot of dirt in it, connected it again, but still the water coming out of the jets is like you want to pee but you can't.
Anybody out there who solved this problem before?Thanks for any advices Thomas
I think the nozzles are blocked. What happens if you pull off the pipes that go to the nozzles. Get water spraying out then?
