Hello,
is there someone who can post/mail me a pic from the workshop manual/service manual of the crossmembers below the engine.
This is the one before the gearbox mount cross-member.
Can't find it in the electronic manual downloaded from the forum,
want to replace it due to damge but need to know how much work it is.
Neil.
Thanx Marius,
the second pic is the one I'm looking for.
The crossmember marked as part 32161, that is my problem, but it seems like a bit of work to replace(i can get hold of a secondhand one), so maybe I should try my imagination for another solution to my problem which is the bashplate mounting points on that crossmember, they are damaged so I cant fit a plate.
N.
N.
Neil,
Maybe try and tap the holes to a different size and install new tensile bolts
