Losing my head - in need of professional guidance
Posted: Wed Jul 18, 2012 8:31 pm
Hi forum members,
A cry for help (and a bit of commiseration wouldn't go amiss too).
My 2002 Gen3 LWB Auto paj and I have been in relationship since 2005 (since about 70k km).
I swear I have never mistreated her and have always been faithful.
I tow a Halcat from Jhb to Bronkhorstspruit once a year maybe.
In all the years I have had her I have never seen the water temp needle go above horizontal.
I rarely exceed 2600 rpm, preferring to travel at 2000 rpm highway driving.
She purrs along, does not use coolant, does not use oil between service oil changes, and gets better consumption than many despite ARB + long range tank + roof rack.
Knowing that grande dames of her experience - 225 k km (lets not talk about age) may experience some dental problems I promised to replace her upper timing chain guide.
So today I took off all the paraphenalia to get to this - my goodness - with my Beetle it just used to be a spring clip and you had the rocker covers off - nothing that simple for the cunning Japanese. (It leaves me wondering what you short guys do when you have a raised paj with an ARB bar?)
Sure enough the original upper guide was in the process of failing - a crack near the leading edge of the bearing surface of the guide.
Easy enough to fix with a new guide.
But wait - what's that? Cracks across the head on the section on which the second camshaft holder sits.
Oh cr*p.
Q1. What do I do now? (Given that I must continue the relationship)
Q2. What can let go?
Q3. What can be the consequences of that letting go?
If I had not taken the rocker cover off I would have been none the wiser.
Oh cr*p.
