Service oil
Posted: Fri Jul 27, 2012 9:23 am
by PIRI D-ID
whats the pros & cons of castrol gtx diesel?
Re: Service oil
Posted: Fri Jul 27, 2012 10:22 am
Pros
- good marketing
- available almost everywhere
Cons
- Many reports of Castrol causing sludge.
Re: Service oil
Posted: Fri Jul 27, 2012 10:41 am
IMHO:
Castrol Mineral oils - stay away.
Castrol Full Synthetic oils - good quality.
Good mineral alternatives:
  • Caltex Delo400
  • Shell Helix Ultra Diesel
  • Shell Rimula
Why do I say that, and recommend the above oils?
I have heard many a negative comments about the Castrol oils, but not about the listed oils.
Why take the chance, then?
Re: Service oil
Posted: Fri Jul 27, 2012 11:58 am
by PIRI D-ID
I will go with delo400 next time, does it mean that i have to drain the gtx diesel oil after just 1860kms as adviced by a workshop? :shock:
Re: Service oil
Posted: Fri Jul 27, 2012 12:32 pm
PIRI D-ID wrote:I will go with delo400 next time, does it mean that i have to drain the gtx diesel oil after just 1860kms as adviced by a workshop? :shock:
You will have to make that call, but I would not have.
One sump full of a specific oil (which in this case does actually comply with the required spec) should not be a problem. Long-term use might cause some problems though.
PS Many users swear by Castrol GTX Diesel, so I don't think it is outright "bad".
IMHO there are however oils with a better reputation available, albeit at a higher cost.
Re: Service oil
Posted: Fri Jul 27, 2012 1:57 pm
by PIRI D-ID
Thanx for the input 4e x 2 :) i will stick to delo400
