Christoff
HELP NEEDED
Hallo i have a 1996 lwb 3.5l dohc and the bolt on my crank pulley broke and because of this I am stranded in bloem and the local benz dealer cant order because of the striking.
Can anyone help me with either a supplier or with a bolt im willing to buy it and pay the postage im desperate please help :cry:
Swartjan
Re: HELP NEEDED
Try Mitspro,
012 644 2888
Blessie
Re: HELP NEEDED
Hi Christoff, dont know if you got one by now, but try Martin at cell 0832847734
Re: HELP NEEDED
Good read here on extracting broken crank bolts on those engines
Crank Bolt failure
Those engines are notorious for that problem.
Bolt has been revised twice
old bolts are these - oldest on the left and first revision on the right
The new 3500 bolt is LEFT - LL1100A141
The New 3000 bolt is RIGHT - 1101A022
this is based on info given by wincaps and mitsubishiparts.net
Wincaps give this part number for the Gen2 3500 longwagon
- 030313 - MD172725
it looks like the OLD bolt on the right in the top picture
when I enter the part number MD172725 into mitsubishiparts.net it gives this revised part number which is the bolt on the left in the picture above as mentioned part number - LL1100A141
Christoff
Re: HELP NEEDED
I just want to say thanks! Thanks for all u guys!! al die moeite wat julle manne doen vir my en mekaar!! proud jerry owner!!!!
Grant4u
Re: HELP NEEDED
These are contacts who have helped me in Bloem:
Engine Parts, Hilton at the bottom of Zastron....tel: 051 409 2700
Engineers who can maybe make one: Hugh Cameron at Jomaka (JMJH) tel:051 448 4026 (just behind Engine parts)
Last resort: Engine Den in Pretoria do lots of Pajero parts(but you have to sort your own courier) tel : 012 386 2786 /7 /8
You need to be sure its the bolt and not the pulley itself tho.....that pully tends to crack at the shaft and cant be fixed....Engine Parts got me a second-hand one for R900
Good luck!
