Please help, i have just checked all fuses by removing them, rplaced some that appeared missing under dash, also dio the same in front as well as removing all relays and cleaning the contacts - now the engine check doesn't work, neither do some guages and power windows either.
1999 Pajero iO Manual
Sorry to hear but maybe this helps. Doublecheck your fuses .Only put fuses where there should be and make sure you have the correct amperage because if I remember correctly the blades of the different fuses are different thickness, ie the 5 amp blades are thinner than 7 amp and will give a bad contact.
I hpe you win.
I hpe you win.
