Dual Battery System - Planning
This is how I planned the bracket for the second battery I wanted to fit. I ended up using solid 2mm plate instead of making a frame as indicated on my drawings.
Template of the battery bracket 16122012.pdf
(1.47 MiB) Downloaded 206 times
Re: Dual Battery System - Planning
Nice! How much is this going to cost you?
Karl
Did not cost me much.
Cole Hersee relay from agents was R155. Steel plate R30, brad harison connectors R30 each x 4, battery donated by client but value R 1000, cable R 150. Most other parts needed I had lying around as I am in the electrical industry. Labour Free
Plate R30!!
I've had a quote for a R1000 to get a plate made to fit the battery on its side!!!
