jaco_n
Time reset
For the past couple of months, after somebody drove into the back of me, my time keeps on resetting on different occasions. I cannot not determine under which conditions it will reset itself. The date will still be the same, just the time that will reset. any ideas please.
Re: Time reset
check the connector behind the dash and double check your grounds from battery to chassis and engine to chassis.
Re: Time reset
What model Pajero? On the GEn3 there is a setting on the radio that tell it to syncronise the radio time to the time that is transmitted by the radio station. Unfortunately not all radio stations seem to keep their clocks up to date and this then sets your clock out. Check the user manual on the setting and disable it if this is the case.
jaco_n
Re: Time reset
Hi Cats
That's somehting new to me and very interestng. Will have to look at the manual then. Myne is a 2005 GLS, 3.2 Did.
I always have it on KFM though..mm
jaco_n
Re: Time reset
I've checked the battery connection to the body, still in good nic. Trying to find the engine earth to the body though. Time sync is not activated.
How do i get to the back of the dash to check the connections?
