jays7
Some queries
Hi guys, Hope you can help me with some of my questions i have with my Pajero. its a 4d56T. Recently There have been small oil leaks I noticed on the garage and when I tried to look where its coming from, it looks like it came from this. (See red mark on pic)
I am wondering what could be the cause of the leaks?
Thanks guys ;)
Re: Some queries
I assume it is engine oil and not gearbox oil.
Difficult to say from one pic, but nine out of ten times will oil dripping from there indicate a worn oil seal on the back of the engine.
Klause
Re: Some queries
Hi, ek het ook n soortgelyke lek op my Pajero 3.2 ge kry en dit was die "oil pressure sender unit" Dit is naby die olie filter ge installeer! Maak ook seker die olie filter is goed vas!! Ek het al ge kry dat my kar se filter los raak met tyd.
