Boost Sensor and Butterfly on my DI-D 2002
Posted: Mon Feb 18, 2013 3:05 am
by BenjieMan
Hi Everyone, greetings from Central America!
I would like to ask you about the symptoms of a faulty Boost Sensor and Butterfly on a DI-D 2002, my Montero is being slow and weak going uphills, scanner says butterfly and boost sensor, now,is there something I need to check before changing these two sensors? I have moved the injection pump forward to get rid of the excesive gray smoke. Thanks in advance! ;)
Posted: Mon Feb 18, 2013 7:29 am
The boost sensor is located next to the diesel filter.
To eliminate the butterfly just unplug the 2 vacuum tubes at the throttle body or disconnect the electrical plug. ( you will have either the vacuum tubes or electrical plug, not both) - doing this will light up the CEL but will not affect driving performance (ie. no limp mode)
Sent from my iPad using Tapatalk because forumrunner keeps crashing on ios 6
Re: Boost Sensor and Butterfly on my DI-D 2002
Posted: Thu Feb 21, 2013 3:16 pm
by BenjieMan
Thank you!
