Fiddled around, and was lucky to see that the idle butterfly had got stuck in the open position, tapped it with my finger, and it closed, car started as normal and was fine for the rest of the day.
Has happened a couple of times since then, so I cleaned it from the outside with carb cleaner. All seems to be ok..!!
