Lumberjack
Shock Absorbers
After a recent trip to Mana Pools I found that the shock absorbers on my 2012 SWB require replacement. Not sure whether I require all four or only the rear shocks but will have them tested. Any advice on what make I should choose and a supplier in the East Rand area?
Re: Shock Absorbers
If it's a 2012 then surely it will be covered under the maintenance plan.
It's way too early for them to fail - must be factory defect.
Lumberjack
Re: Shock Absorbers
Thank you, I will certainly explore that option.
