Hey guys, I know this subject has been covered on other threads, However I cannot find any clear instructions on how to determine if the electronic panel behind the dash cluster should be replaced or not. R2225.00 for a new one so I want to be 100% sure its causing the problem. anyone know how to definitively test it?
Mine did the same thing, Sac in Centurion put a new unit in for me and if I remember correctly it was about R500.
Maybe give them a call and find out.
Henk
Henk
It was just for the part, couldn't tell you how much the labour was because it was done with a few other things also.
good luck
good luck
Hi Henk,
I called them, They dont have a clue what Im talking about, any chance you can provide the invoice number so I can get them on the same page?
There is a very nice video on youtube that explains this process and a DIY repair. Cant access it right now but do search for "temp gauge cluster repair mitsubishi montero pajero" and you should get it.
PM's not working...
The account number where they fixed it was 30199101
The part number they used was: MD050214
The date 10-06-2011
You can emial me directly at slowlaner@gmail.com
The date 10-06-2011
Hello from Stockholm, Sweden !
Probably no need to replase the curcuitboard , just resolder the R10 resistor on the bord.
I had the same problem.Removed the curcuitboard and took it to a Place where they repair cellphones, because the R10 resistor is very small.He resoldered it, i put it togheter and problem fixed!
There is lots of information on the Australian pajero forum.
Theo
Theo
Found the youtube video!
Here it is.
https://www.youtube.com/watch?v=HTqxmSL ... ata_player
Here it is.
That is a Good video, i used it ...but im 99% sure that you just have to resolder R10 resistor.the Money is nothing compared to a New circuitboard.....pull it out, go to someone who knows how to solder tiny things.it sägs R10 on the resistor, cant miss it....did mine at the cost of a few beers...
Theo
Theo
