I am in the process of purchasing a 2008 Gen SWB. It comes without a towbar. I need good recovery points at the back. Installing just any towbar and adding a pall & pin hitch is not an option, I want recovery points left and right.
I have 2 options: a replacement rear bumper from Lynx, who else is there that manufactures and installs?
or
A towbar with a ball& and pin in the middle and recovery points left and right of the cross member. Who makes these?
Does the Frontrunner towbar look like this? Pic pls
I understand that the BTM towbar might be like this. Does anyone know?
KP Rural,
Try a DUYS tow bar. The bar has recovery points on both sides, has all the correct boltholes to mount it properly and fits snugly under the plastic cover. The actual ball and arm unit can easily be removed and then you can only see the cover - approx. 60mmx60mm. It does not stick out below the plastic cover like a pair of old and dirty underpants
Cloyd
Cloyd
