Reserve kilos.
Posted: Mon Jun 01, 2015 2:07 pm
by Kapow
Hi there guys,
Can anyone advise me as to how far can I push my little orange fuel light on a Gen 3 3,2 DiD SWB?
I don't drive with a heavy foot at all - it would just be interesting to know how far I can expect to get on the reserve light before filling up...
Shot, Craig.
Re: Reserve kilos.
Posted: Tue Jun 02, 2015 7:11 am
by JohnG
The most i have pushed mine was 80km.Too scared to run it dry for the pumps sake
Re: Reserve kilos.
Posted: Tue Jun 02, 2015 8:05 am
by Nick Gibson
In my lwb, when the light comes on I can only put 70lt it. That leaves 20lt for reserve on my 90lt tank, and at about 8.5km/lt it equates to about 170km range.
The swb has a 69lt tank, drive it until the orange reserve light just comes on and fill up. You can then calculate the reserve capacity and then the range based on fuel consumption.
It is however not advisable to run your tank below 1/4 often due to part of the diesel being recycled back to the tank past the fuel pump and injectors for cooling purposes. This process heats the fuel up considerably in the tank due to the smaller volume left in the tank to dissipate the heat, and is apparently bad for the pump and injectors.
Re: Reserve kilos.
Posted: Tue Jun 02, 2015 9:07 am
by Roelf_le_Roux
Hi Nick,
I agree with your point on low tank levels and heated diesel. Warm diesel loses lubricity.
Re: Reserve kilos.
Posted: Tue Jun 02, 2015 9:59 am
by Kapow
JohnG wrote:The most i have pushed mine was 80km.Too scared to run it dry for the pumps sake
I have heard about the extreme care needed with regards to the fuel pump. Hence my question. 80km is considerably further than I have pushed the yellow light in and around town. When I collected the car I pushed it about that, but it was on the open road on the way back from Durbs. Thanks for the feed back - good to know these things.
