Hi all I have Mitsubishi S.A. Blank Service Sheets for Pajero Diesel, Pajero Sport Diesel and Triton Diesel Models.
I have Uploaded them to the Technical Library, check my post of the 7th Jan 16 and you can Download what you need.
Hi Terry,
Please send me a service sheet for Pajero DiD. My e-mail address is musk@telkomsa.net
Many thanks
Many thanks
Hello. What is the use of a service sheet? Does it tell me what needs to be done at each service?
I would be interested in that
Gbkirchner@gmail.com
Sent from my mobile device
Yes, it tells you what Mitsubishi recommends (or insists???) gets done at each service. So when you book your car in you can ask them for a quote beforehand and check that everything that should be done gets done. I received mine and it is awesome to be able to see what needs replacing versus "checking". Well worth it.Ritteling wrote:Hello. What is the use of a service sheet? Does it tell me what needs to be done at each service?
Please send a sheet for the pajero 2003 did auto to allangdell@gmail.com
Sent from my SM-N910H using Tapatalk
terrys,
I have a 2004 3.8 Pajero and assume that apart from the engine itself the rest of the service sheets will be valid for the 3.8. If possible please "e" mail me sheets for the Gen 3 Pajeros. Address: cloyd@telkomsa.net.
Regards,
Cloyd
Regards,
Cloyd
