Low range ratio change
Posted: Mon Mar 07, 2016 8:40 pm
by Lynton
I would like to know the feasibility of reducing the low range ratio in the transfer case.
If anyone has had any experience with this please let me know.
Re: Low range ratio change
Posted: Tue Mar 08, 2016 9:59 am
by Roelf_le_Roux
Lynton,
Your question is going un answered, but I have not come across anybody that has actually done it. I drove Pajeros for so many years, that I just accepted it for what it was, but my new Isuzu has opened my eyes to the benefit of a nice low crawl gear.
Play around on YouTube and you will find a few videos where Pajeros play with other makes in the rough - it is very obvious how much faster the Pajero goes through the obstacles due to the higher Low Range. What is important to notice though: they always make it through. The whole Pajero package is well designed and well engineered.
I'll keep an eye on this post
Posted: Tue Mar 08, 2016 10:31 am
If there is a crowd that can help you, it will be the members of th 4x4Wire forum
The yanks have a fetish about crawler gears.
Join there and ask.
Posted: Wed Mar 09, 2016 7:21 pm
by pfgrobler
marks4wd imn Australia has the following :
Mitsubishi Gen3 Low Range Gears 66% - 3.15:1 Reduction - Auto
Part Number: PAJ-GEN3-3.15A
Mitsubishi low range gears - ratio 3.15:1 - automatic transmission
To suit Generation 3 transfer case - 23 tooth (spline) input gear
Montero
Pajero
Shogun
Availability: In stock
$1,495.00
It sounded very promising but from pajeroclub.com.au I wasn't sure if they still make them.
http://www2.pajeroclub.com.au/forum/sho ... hp?t=48197
http://www.marks4wd.com/low-range-overd ... 3-15a.html
Posted: Wed Mar 09, 2016 7:33 pm
by Lynton
Thanks for the responses guys... Appreciated.
I should have said that mine is a 2001 Gen 3 3.2DiD Manual.
I will follow up with Marks 4wd in Aus but I was hoping to find something local.
Thanks Guys.
Posted: Tue Mar 15, 2016 9:23 am
by JGK
Speak to Martin from Parthunt 083 284 7734
AFAIK the Gen3 petrol and manual has a 4.1 ratio. It is a direct swap. I had 285/75 on my gen3 Did and wasn't happy with the power and fuel consumption and considered this mod, was feasible but expensive. Have reverted back to standard tire circumference. Awesome mod, with 285/75 tires, if you can afford it.
