12V 'Cigarette Lighter' replacement
Good Morning! The 12V plug in the front console of my Gen4 (2007) Pajero is not working. Apparently it is the unit and not 'just' the fuse. I phoned the dealer and they quoted me R800 for the part!! Plus R350 labour to replace. If I remember correctly, this unit has a built-in fuse (?) which makes it very difficult to replace a fuse when and if it blows! Is there maybe a handy 'sparky' in or near Pretoria that has figured out a better way of doing this without burning out the car? Your input and advice would be appreciated.
Re: 12V 'Cigarette Lighter' replacement
Why not replace it with this handy combo?
12V USB Combo
12V USB Combo
USB_12V Plug.jpg (6.92 KiB) Viewed 5737 times
That certainly looks nice! AND practical :) Do you know if it fits into the available space in the console? And the other question is that of the fuse(s)?
Just install a fuse in-line when you install it, or find a vacant fuse slot on the fuse box.
Any even half competent sparky will do that.
andre1
Looks like a nice combo.Who stocks them?
Hi NatureFan
There is a fuse on the lighter unit itself, in the form of a "melt" wire that, umm, well melts when overheating. Fixed mine with a piece of soldering wire. Took longer to remove and replace the unit than the fix! :)
3200 Tdi GSL 2001 Written off
3500i A/T 5Dr 2001 Sold
3.2 Di-Dc GLS A/T 2008
4x4 pret
Hi Nature Fan
I experience the same problem with my center console plug after plugging in a faulty fridge. :x All my fuses front & under the dash is in tact, yet the plug does not work.
I am definitely going to follow Andre's advice. Thanks Andre
Lock wrote:Hi NatureFan
Hi Andre, thanks for the tip. I had a feeling there was something like that afoot because I seem to remember I had the same problem once before but it was when the car was still quite new (i.e. a LONG time ago!) ;) I did not know that the so-called fuse was nothing but a piece of "melt" wire!
Unfortunately I have absolutely no idea where to start to remove the unit/panelling and therefore still have to find an auto-electrician that knows how to remove the Pajero's dash without breaking all those tiny little (and by now no longer so flexible and...and....) clips.
