Icelandic 3rd gen Pajero on 44in tires!
Posted: Sat Oct 29, 2016 9:20 pm
Hello fellow Pajero owners,
I'm a norwegian just moved to Iceland, and have got hold of a 2006 Pajero 3.2 DiD automatic. Never before have I had so much fun on 4 wheels! On Iceland it is completely illegal to drive offroad, but some of the "roads" and tracks are so bad that you will have plenty of fun anyway. And not to mentioned the bridges, or missing bridges, so you have to drive through most of the rivers.
Some challenges... I have already flooded both diffs and then replaced the oil, but have a leaking seal/gasket on rear right axle. Think I need to replace the diff breather hoses, they might have hole and leak. Also ABS light is constantly ON, fault codes says faults on both front sensors (wire or sensor trouble), and sometimes problem with the SuperSelect flashing when switching between 2H and 4H (both front lights blinking green, or all off and just center diff blinking)
The car is equipped with extra low gear option, has ARB locker on front, air-compressor installed, extra diesel tank, extra lights, +++
Missing a snorkel, but will try to get it installed. Same for winch!
More later, gotta run! Advices for repair is welcome
If anyone want to see specific pictures, let me know. Think it is alot of nonstandard things on this car...
Have a nice weekend,
all the best from Gard
