Oil leak on front Prop Shaft - advice needed
Hi There
I have noticed a small oil leak on my garage floor and on inspection found a drop of oil on the cowling (looks like a tin can, see attached pdf with red arrows showing the point of leak) just before where the prop shaft enters the transfer case. I cleaned it and unfortunately it has re-appeared.
1.0 Is my assumption correct that it must be a seal between the transfer case and the front prop shaft? See attached pdf drawings
2.0 I replaced the transfer case oils last year and is it possible that I over filled the transfer case and now the leak.
3.0 Is this a do it yourself fix and if so anything I need to know before attempting the fix
4.0 Is the oil seal readily available
5.0 Would this only leak if I was in 4x4?
Any good advice woul be appreciated.
Paul
Prop shaft oil leak 01052017.pdf
(196.54 KiB) Downloaded 391 times
Pajero Prop Shaft 02.pdf
(2.72 MiB) Downloaded 328 times
