play247
Pajero Remote Case
Hi All. I have a 2006 Pajero (LWB 3.2) and both the cases for the remotes have given up the ghost, so I assumed others could have the same issue. I have found a supplier overseas, so going to give it a try. It is the 2-button remote and - according to the spec it will work for all Pajero's from 2004 - 2015 EXCEPT 2009, 2010,2012 (not sure why - and not sure how that stacks up against SA models). Below is a pic of the case - please let me know if you are keen and I will order extra - no risk - I am doing it anyway, and not even sure if they will work!. PM me if you are interested... Below is the link...
https://pallmart.com/products/car-remot ... w7EALw_wcB
PLEASE NOTE : This is not the remote - this is the plastic case only, so you will simply move the working parts across..... With international air freight, it will work out about R150-200 per unit....
Re: Pajero Remote Case
Hey
Give Mitsubishi Used Spares a call.
I seem to recall a FB post that they recently brought in a bunch of remote cases..
0121111077
