Bluetooth radio for 2005 pajero
Posted: Fri Oct 06, 2017 2:47 pm
by littleman
Hi everyone.
I want to replace the original factory fitted mitsubishi radio (which is not bluetooth/does not have USB port or audio jack) with one that has these features. I was wondering if a later model paj radio that has these will fit into the space of my vehicle. Any advise will be appreciated.
Re: Bluetooth radio for 2005 pajero
Posted: Sun Oct 08, 2017 6:10 pm
by play247
Hi there. Not too sure what you have in there. Perhaps if you post a pic? I have the 2006,and what I did was remove the radio/tape and the Cd unit. Then moved the Airton unit to where the Cd was, which left a standard double din space. You can then buy and install any double din unit. I put in a Sony Xav 68 BT which has all the bells and whistles (including Bluetooth). Is that the sort of info you need?
Posted: Sun Oct 15, 2017 2:17 pm
by h_hezzah
Hello,
Either you do as play247 said, for installing a double DIN unit, or you can simply get a single DIN with Bluetooth (most brands have a BT in the Model name), replace the original unit and leave the CD unused in its place.
I had both scenarios and both work fine.
