Good day members,
My name is Willie Cilliers and I am from VOLKSRUST, MPUMALANGA. My ride is a 2010 PAJERO 3.2 Did GLS LWB. 194000km on the clock. The problem I have is that from time to time the following warning light on the dash comes on:
ASC; Traction Control; Centre Diff and Engine light all at the same time.
No loss of engine power or anything else just that these light comes on. When switching the ignition off the ASC, Traction control and Centre diff light clears.
The engine light clears after a couple of starts or if my Pajero agent clears it by using the M.U.T. After many times we eventually could find the following Trouble codes with the M.U.T.
P0106 Baro/Map sensor ( Active )
U1120 Engin data error ( Active )
U1121 Transmission data error ( Stored )
Anybody out there that have an answer or a solution to this problem please advice.
Kind Regards
Willie Cilliers
Phone Arnold Venter at Mitsi Tech. 076 402-0046 or 081 549-2543. He’s a fundi and should be able to help you out.
Good morning Kurt
Thanks for your feedback. I will just do that and phone Arnold. Will keep the group posted.
regards
Willlie.
regards
Willlie.
Hi Willie,
I have the same issue. What was the outcome of yours? Did you manage to solve this?
