Diff lock on the 3,2 Gen 111 Pajero SWB 2005
Good day to all, can someone please assist with some info on the functioning of the diff lock on the Gen 111 2005 SWB. Is the diff permanently locked in on the back wheels and is the 4x4 lights centre orange light an indication that the diff is locked or does it have a different function. I do not have a owners manual to refer to on the correct functioning of the lights. Please I would appreciate any help I can get, the lights are all flashing then only just the back and keep on changing when I stop and start. The 4x4 is also not engaging however if I swap the vacuum pipes manually the 4x4 engages...... Please help I have run out of ideas...
Re: Diff lock on the 3,2 Gen 111 Pajero SWB 2005
There so no rear difflock on that model and you need to ensure that your center difflock is not engaged when driving on tar. Place the gearlever in Neutral and adjust it back to 2H and then see what happens.
