Hi All,
I have a problem with the indicator stalk on my 2005 3.2 GLX. I have to hold it tightly up or down for it to work (in clicks into place and releases back normally but have to force it up hard to make it flicker)... also the headlights seems to flicker on and off every now and again... probably stalk related as well.
Any ideas as to what it could be... worn stalk / connection maybe...???
Can I just open the cover and poke around??
Gazza
There was a free recall to get this replaced and it took about 1-hour at the agents. Check if you still qualify for this free replacement.
Thanks, appreciate it! Will check it out
2005 Pajero 3.2 D-iD GLX
Morning Gents,
GAZZA - want to check, did you manage to confirm about the recall and free rectification thereof? My 2006 is doing exactly same!
Regards,
Marius,
0828864849
Regards,
Marius,
0828864849
I just got off the phone with MARISKA at Mitsubishi Centurion who confirmed, and also booked my Shorty in for the PC BOARD ON HEADLIGHTS recall.
She first wanted VIN number to confirm recall is applicable to my vehicle, then also needed the Engine number.
So mine is booked for next Tuesday for the repair/replacement.
Cheers,
Marius.
Cheers,
Marius.
