Error code 33
Posted: Thu Apr 09, 2020 4:25 pm
by lichtenburg63
I urgently need advise with regards to the following dashboard lights on my 2005 Pajero 3.2 DiD: center lock light flashing, traction control OFF light on, traction control light on and no green rwd and fwd lights at all. I checked the fault codes to be code 33. As we are all locked down, I cant ever get assistance from the dealers.
Any suggestions will be highly appreciated.
Re: Error code 33
Posted: Fri Apr 10, 2020 8:18 am
by KurtG
It’s probably the 5 switches on top of the transfer case that controls the SS system. I had to have mine replaced a while back when my centre diff lock wouldn’t disengage.
Re: Error code 33
Posted: Fri Apr 10, 2020 10:20 am
by lichtenburg63
Thanks.
With no spares available, is it possible to pre-determine which switch it can be, remove it, and try some home fix?
Re: Error code 33
Posted: Sun Apr 12, 2020 11:49 pm
by limuman
Hi, I had a similar issue a couple of times. In my case this happened while driving. The center diff lock starts to flush and at the same time the rwd green lights go off. the first time this happened i just ignored it until I got to my destination (about 30KM ).
When i restarted the car everything was back to normal. The second time I did the DIY fault check and got code 33. I disconnected the battery for a while and reconnected. Started the car and checked for errors- Nothing.
obviously this just clears the error but it does not fix the problem. Have not figured out what the problem actually is.
Since we also in lock down here (Botswana), I guess I will be taking a close look at those 5 switches as suggested by kurtG.
Re: Error code 33
Posted: Mon Apr 13, 2020 8:04 am
by lichtenburg63
From all forums, it seems to be a common problem, with various signs. One guy's success is not a guarantee for the next. I disconnected the battery several times, to "reset"the fault but as soon as it is reconnected, before even starting the engine, the CL-light flashes again.
Seems to me I must apply the definition of stupidity: "Expect different results by not doing things differently" :roll:
