Tail lights grounding
Posted: Mon Aug 17, 2020 10:22 am
by PajeroNewbie
Good Morning
Gen 3 2001 3.2DiD Pajero
my drivers side tail light goes out when i press the brake, i believe this is a grounding issue?
Please could someone tell me where are the groundings i need to check for this?
are there any other symptoms i need to check?
regards
Mark
Re: Tail lights grounding
Posted: Mon Aug 17, 2020 10:42 am
by Mitsu Fan
My 5c is that there should be a ground connection very close to the light unit, or on the left side unit.
Start there.
Also check the tow hitch plug for a possible loose wire. Thats where I think the problem may be. If it was a ground connection then all the lights connected will be faulty.
Good luck
Sent from my SM-G960U1 using Tapatalk
Posted: Mon Aug 17, 2020 1:40 pm
by PajeroNewbie
Thanks for the comment
it does make sense that if it was a ground issue then it would happen to all lights not just the one, have changed the bulb, not that!
will look and see as you suggest
