HELP! Gen 3 Pajero Cut Out
Hi all,
My poor lady hasn't been so good.
Recently while driving on the highway, the car completely died. Coasted to a stop, and she started up again just fine. A few weeks went by and it happened again - this time while going from drive to reverse. It has also happened sitting at a stop street, pulling out of my garage and the like. So there doesn't seem to be much common thread here.
I took it to my mechanic and this was their response:
-THERE IS A SIGNAL PROBLEM TO THE CONTROLLER SOLENOID SYSTEM. WHEN WE RUN THE TEMP EARTH THEN THE THROTTLE VALVE ON THE INTAKE WORKS 100% BUT THE TURBO DOESNT BOOST. WE SUSPECT WIRING PROBLEM OR RELAY PROBLEM FOR THIS CIRCUIT. WE HAVE SEEN TWO PAJERO'S IN OUR SHOP RECENTLY WITH A SEPERATE RELAY BOX WIRED INTO THE ORIGINAL.
-VEHICLE TO GO TO A AUTO ELECTRICIAN
Went to the auto electrician, they found a crack in the fusebox and repaired that. The problem still persists, and the electrical circuit is working properly.
Any sound advise is much appreciated.
Matt.
Re: HELP! Gen 3 Pajero Cut Out
Recently bought a 2010 Pajero Sport 3.2 DiD and it started to cut out intermittently. No idea what the problem is to date. Help on this issue will be much appreciated.
Johan
Suction control valve is a potential cause
KurtG wrote: ↑Sun Mar 14, 2021 10:09 pm Suction control valve is a potential cause
Thanks Kurt - I'm going to have a look at that at the workshop tonight - do you have a diagram/location for me where I can find this?
Cheers,
Matt.
