Gen 3 front transfer case making a loud noise.
The 4x4 switches are working, the car does go into ALL the 4 Wheel Drive gears, however when going into 4 wheel drive it start off ok then there is a type of loud squeaking noise its in all the gears. When the car is in 2 wheel drive occasionally there is also a loud 'squeaking' noise and then if you slow down just before the car comes to a stop there is a loud thud noise (you can feel it as well) , sounds like gears that are disengaging . Please can you guys give me some feed back on what is wrong and what needs to be done to fix the problem.
