6G74 Engine for 2002 LWB Gen3 Pajero required
Posted: Tue Jun 29, 2021 10:57 pm
by Henrycharlesmuller
Hi all
My 2002 LWB Gen3 Pajero popped a water pipe, motor overheated and ceased, cannot be repaired :(
I'm looking for secondhand motors to replace the above-mentioned paperweight, please let me know if you can help locate one that is for sale.
Kind regards
Henry
Re: 6G74 Engine for 2002 LWB Gen3 Pajero required
Posted: Sun Jul 04, 2021 9:02 pm
by ROBNICK@50
Hi theres a company in Joburg that imports engines. These guys might be able to help. If you get easy to change timing belt tensioner whist it's out. Check core plugs also. Good luck.
Sent from my SM-A205F using Tapatalk
Posted: Sun Jul 04, 2021 10:22 pm
ROBNICK@50 wrote: ↑Sun Jul 04, 2021 9:02 pm Hi theres a company in Joburg that imports engines. These guys might be able to help. If you get easy to change timing belt tensioner whist it's out. Check core plugs also. Good luck.
Thank you Rob ... I found an engine at Engines for Africa, apparently imported from Japan, and it has less than 100 000km on the clock - will have it properly checked out when it arrives in CPT, but very hopefull that it is good and will last me for a long time!!!!
