Are the Mitsubishi shims for sale on eBay what one needs to solve the common negative rear camber issue?
I can't find any on eBay right at this moment that I thought I saw before for the 3rd-gen but these are similar and for the 2nd-gen:
https://www.ebay.com/itm/114175539087
My rig has 530,000km, and I suspect that others with Pajero / Shogun / Montero have the same alignment issues caused by the same problems (and therefore with the same solution or replacement parts required) if they have a similarly high number of klicks on the clock (KM on the odometer).
Would putting 1cm shock mount spacers on all 4 wheels help? Sourcing parts is generally difficult and problematic for me. I do have heavy nylon "lift" spacers already which can be installed on the shock absorbers. I could get eBay parts if I had to.
Any help would be most appreciated!
