2008 Pajero ATF dipstick
Posted: Sun Dec 12, 2021 11:10 am
Hi all,
Since I brought my LWB second hand a few years back I have had problems re-inserting the ATF dipstick. The vehicle is normally maintained my Mitsu locally but his year I decided to do the oil change myself which went without a hitch.
Decided to check the auto ATF level and again I can't coerce the ATF dipstick the full length. It gets to the final bend (the 'pin' just short of full length is just outside the dipstick pipe by around 20mm) but it won't go any further (I can feel it bending).
Tried a very light 'smear' of engine oil (don't have any ATF so wiped off but still one can feel the lubricity) to no avail. Have tried 'reversing' the stick (it only goes in on 2 positions at 180° because of the first bend) also.
Is there a 'trick' to reinserting the ATF dipstick?
Mitsu have never mentioned a problem in their maintenance reports (and they should be checking ATF level).
I have previously (after many attempts) been able to coerce the dipstick back in but the problem arises if I decide to check the ATF at a garage 'on the road' and can't get it back.
The dipstick looks fairly straight, other than the 180° 'twirl' towards the end, with no obvious 'kinks' .
Trying to sort out the problem permanently.
Hopefully someone has also battled and has some suggestions?
Many thanks
Many thanks
