Battery Drain
Posted: Mon May 23, 2022 2:55 pm
Hi All. Hope you can help with this conundrum. Purchased a 2012 3.2 Exceed in December and loving it. Car has a ghost though. Every now and then the (brand new) battery (Duracell 95 Ah SAB 650 S) is drawn down to below 12 V after standing for as little as 1,5 to 2 days. Does not happen every time. Took the car to the Mitsu advised autolec in town. After 2 days was called to collect, no fault. Same weekend battery again drawn down. So I started to You-tube and discovered 'parasitic battery drain test'. When I did this test, the reading would be 0.01-0.03 A (10-30 milliamp) which from what I have read is normal. Apparently anything up to 50 mA is considered acceptable for a modern car with electronics that have to remain on. By this time I was going nuts, could not measure the drain, but battery was loosing voltage in hours (12.7 V to 11.9 in 18 h). I then came across a little device on Takealot and acquired it immediately, the Battery Monitor (R580). Size of a match box with two wires. Connected it to my battery and can then get a reading of the voltage via a blue tooth signal. Now I could finally see what was going on without popping the hood. I was now able to detect when the battery was 'bleeding' and when it was not. My hope was that when I caught it in bleeding mode, I could measure the current drain. However, each time it was between 10 and 30 milliamps. Finally I tried doing the test without breaking the circuit. Normally I would remove the negative terminal and connect my multimeter (set to 10 A) between the battery neg pole and the loosened negative terminal. After doing this test you would have to reset the radio, clock etc. In one of the You-tube videos they address this issue by deftly connecting the multimeter without breaking the circuit. I tried this, and voila! 1.2 A current drainage - finally. I then set about pulling fuses to see which circuit was responsible. I had to repeat this about 3 times (long story), but finally narrowed it to the 2 connected fuses in the large fuse box under the hood. You cant remove either of them, they are in a type of box on the fuse box, but can be disengaged, not removed, together. When I pulled these up, the drainage at 1.2 A would remain, but when I dropped them back in, the current drain would decrease to 10-30 milliamps. I am too doff to know what this means, but since fiddling with this fuse I have not been able to get the old goat to go back into parasitic drain mode. Lets hope ignorance and desperation have won the day. Would be interested in any thoughts, advice.
