GDI High Pressure Petrol Pump
- ROBNICK@50
- Country: South Africa
- Vehicle: Shogun 3,5 GDI
Post
Re: GDI High Pressure Petrol Pump
Hi hope you fitted an inline petrol filter. Filters in pump prevent problems with injectors. I fitted inline filter into rubber feed line by bulkhead. Like you mentioned I've had no problems since with mine.
- Gerritport
- Contact:
- Vehicle: 1999 pajero LWB 3.5 v6 GDI
Post
Reconditioned GDI pump working perfectly. Just remember to fit an inline filter.
- Nojotian
- Country: Zimbabwe
- Vehicle: Gen 3 Pajero 3.5 V6 GDI
Post
Had the same problem with mine after a tankful of dodgy petrol. Lost all power and the engine check light would flash whenever i pressed accelerator. Max speed was 20-30km/hr. My knowledgeable mechanic gave me two options
1) Either replace the micro filters in the GDI pump ( expensive, risky-Chinese clones, prone to contamination again)
or
2) Remove micro filters and fit inline filter
I chose option 2 (obviously) and have not had a problem since!!! I change fuel filter whenever I service the car. Its now even tolerant of some of the dodgy fuel we get here!
or
