High Mileage Club (>150000km)
al
allanhmoore
Sun Jun 05, 2016 3:50 pm
Model: 2003 Gen3 3.5 GLX SWB
Milage: 362 000
Original motor: Yes
Any major work? Replaced Brake booster 2 years ago and new back shocks, brake pads, and normal servicing. The motor and gearbox are running well, I love this car.
Rickygee
Vehicle: Pajero 3.2 GLS
Mon Jun 06, 2016 8:54 am
What model / year is your Pajero? 2003 3.2 DID GLS
How much mileage had your Pajero done? 458569
Is it the original motor? Yes
Any major work? No
Ra
Ravensnest
Thu Jun 09, 2016 12:31 pm
What model / year is your Pajero? LWB 2.8TD 1999 Samcor Body
How much mileage had your Pajero done? she sit now on 332000km
Any major work?
New tie rod ends 280000km
Changed universals on main prop shaft 300000 km
New disks front 320000km
Rear disk pads replaced 315200 km
Front oil sensor leaking replaced 300000 km
Stronger battery 90Ah
Repaired the steering unit for the hooter and cruise control.
Turbo starting to make a noise and oil return from turbo leaking needs to be replaced.
Replace turbo 320000km
sw
swiggs
Thu Jun 09, 2016 12:58 pm
What model / year is your Pajero? 1997 Pajero 3000 V6 LWB
How much mileage had your Pajero done? Now on 224300km
Any major work?220 00km: replaced blown head gasket
222750km: replaced radiator, waterpump and timing belt
224000km: replaced inner and outer cv's ;)
Bostokkelos
Vehicle: Pajero GEN 4 3.2Di-D
Sun Jun 12, 2016 7:43 am
Since I have now reached the 150k requirements....
What model / year is your Pajero? 2010 Pajeros Sport 3.2
How much mileage had your Pajero done? 153000
Is it the original motor? Yes, I had to clean a electrical plug on the air intake
Any major work? None.
PAJERO 3.2 LWB GEN 4 AUTO
jd
jdietrechsen
Mon Jun 20, 2016 1:47 pm
What model / year is your Pajero? 2007 GLX 3.2 DiD
How much mileage had your Pajero done? 258'000km
Is it the original motor? Yes, all Original
Any major work? Nope, battery every 2 years :evil:
Na
Namboer
Fri Jul 15, 2016 7:50 am
What model / year is your Pajero? SWB 3.5 2000
How much mileage had your Pajero done? 250,000 km
Any major work?
Shocks 150,000 km
Electric petrol pump 120,000 km
Release bearing 180,000
Re
Renaudsnyman
Mon Aug 15, 2016 8:24 pm
[quote="SimonB"]Christo's post on 3.2 DiD longivity prompted this.
What model / year is your Pajero. 2002 3.5 5door
How much mileage had your Pajero done. 270000
Is it the original motor YES
Any major work? NONE
Sent from my iPad using Tapatalk
Mi
Mitsuleon
Tue Aug 23, 2016 5:15 pm
What model / year is your Pajero. 2000 3.2 DID SWB
How much mileage had your Pajero done. 235000
Any major work? Replaced dual mass flywheel with solid one
Ch
Charles Segal
Mon Sep 26, 2016 10:24 am
Pajero 2,8TDI 1999 now on 309150klm
After doing a heavy tow at around 250000klm in low ratio 4x4 got revs too high & blew a gasket, head replaced, new turbo, so going well since then, told my grandson he can have the wheels when im done with it & if he looks after it he can pass it onto his grandson.
Login · Register
Latest Posts
