Christmas Light Dash
Th
ThePajeroMan
Wed Jun 30, 2010 8:49 am
Please Help!!
Last night I hooked up a trailer to the Pajero and coupled the lights, all was fine then the indicators stoped working and a whole bunch of lights on the dash came on and gave me the skrik of my life!! I pulled over to check the fuses but to no avail, the oil pressure, A/T Temp, and some others came on but there was no efect on the power or anything so I continued home just fine and with out indicators.
What could have gone and how do I fix it????
Thanx
Th
ThePajeroMan
Re: Christmas Light Dash
Wed Jun 30, 2010 11:47 am
Niks? Niemand?
SimonB
Site Admin
Country: United Kingdom
Vehicle: 2017 Nissan X-Trail
Wed Jun 30, 2010 1:01 pm
Was everything back to normal without the trailer hooked up?
Th
ThePajeroMan
Wed Jun 30, 2010 2:53 pm
NOPE!! trailer disconected and the dash lights stay on and the indicators still don't work. I don't think it's serius, maybe just a fuse, but wich one??
Ro
Wed Jun 30, 2010 6:14 pm
Yip, it's a fuse.
I also experienced the same symptoms with a trailer, but with dash lights also going dead with the brake lights. There are two fuse boxes, one under the dash and the other in the engine bay. On my 2006 DiD LWB GLS, I was very surprised to find NO fuses in the fuse box under the dash - just wires running through it. All the fuses were in the box under the bonnet. The owner manual as well as the fuse box lid should tell you where to look for the indicator fuse. There should be a few spares in the box as well.
I have convinced myself that the external lights share fuses with the dashboard lights, as a warning to the driver that something is wrong :twisted:
Th
ThePajeroMan
Thu Jul 01, 2010 8:39 am
Thanx Roelf but the lights on my dash came on and have stayed on even after the trailer was removed and the indicators arent working, just to mention that the car must be swiched on for the lights to burn. These are the lights that come on.
SimonB
Site Admin
Thu Jul 01, 2010 9:25 am
I would be worried that your oil light and water trap lights are on as well.
I'm wondering if there is some way to reset the ECU, or something has fried somewhere.
4ePajero
Vehicle: 1989 Pajero LWB
Thu Jul 01, 2010 9:34 am
Try disconnecting the battery (or pull the fuseable link) for 30mins.
Hopefully it resets everything.
Contact:
Thu Jul 01, 2010 9:56 am
Are you 100% sure there are no fuses blown? :?:
I have read of this phenomenon on other Pajero forums and everytime it was traced back to a blown fuse, usualy the indicator one. It seems as if there are a number of things linked to this fuse and if it blows it confuse the ECU somewhat. Definately check ALL fuses in cabin as well as under bonnet and replace the indicator one in any case.
Getting the battery off for a while can also help resetting once the fuses are checked and replaced but make sure you have the radio code before doing this.
Th
ThePajeroMan
Thu Jul 01, 2010 11:18 am
Thanx guys will check all fuses again and then try the battery trick :(
